What does type(fix12_11) mean? and how to set input in FFT
Hi, everyone!
I have serached for so long but I sill can't fingure out what does "fit12_11" mean in the FFT IP.
Does it mean there is only 11 bit of integer part and 1 bit of fractional part?
Also, my maximum of input data is 525. Should I adjust all my input data to xx*2 if I set SCALE_SCH to 2("10 00 00 00 00") ?
What would happen if I set the SCALE_SCH to "00 00 00 00 00"? I think outputs are also near to the correct ones, but why it seems totally different from the matlab results?
Thanks very much!
Re: What does type(fix12_11) mean? and how to set input in FFT
@liutianyang_sari
"fix12_11" is the fixed point number of with 11 bits as "fractional bit".
SCALE_SCH is a part of "s_axis_config_tdata" format. You need to set it accordingly.
Please see page 16 of PG109 for more details.
Thanks a lot!
But R U sure that fix12_11 means there is 11 bits as fractional bit? So all the input data have to be range [-1,1]?
Look forward to your reply!
Thanks!
All the values will be represented as 12 bits with range [-1, 1].
Can you please elaborate your last question? I did not understand your issue with range [-1, 1]?
