mostafa@sint
Where is FFT v9.1 test bench?
Hi All,
There are allways mentioned in forums that use FFT IP core testbench in
demo_tb/
tb_<component_name>.vhd
but I have just made a block design with its HDL wrapper but cant find demo_tb directory
and test bench file.
I am using windows 10 and vivado 2018.2.2.
Mostafa
mostafa@sint
finally I found that when you use an IP in a block diagram design,
it  doesnt generate the test bench. But if you follow the following video for IP instantiation then
you can see the test bench is generated.
https://www.youtube.com/watch?v=-NaRIrFSZ38
Learn how to customize, add and instantiate IP into a project using the IP Catalog. Specifically, the features highlighted include: launch IP Catalog, search...
meherp
You need to generate the output products as shown in attached figure.
Next, please look the testbench inside the .src folder i.e. below location,
<project_name>\<project_name>.srcs\sources_1\ip\xfft_0\demo_tb
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
mostafa@sint
Hi Meherp,
The problem is I cant find "demo_tb" directory anywhere
in the design project. I have also dgenerated output files
and synthesised the design but still there is no "demo_tb"
directory there.
Mostafa
mostafa@sint
