swain168
Why the output of my FFT_IFFT model is incorrect?
 input signal is cos(2*pi/192)(real component) and sin(2*pi/192)(image component)
Simple time is 3,
Simulink system period is 1s,
Down sampling rate is 3,
FFT bolck is FFT v4_1
Message Edited by swain168 on 07-22-2009 05:55 AM
aarunya
um hi,
i have actually switched updated my xilinx sofware ISE 11 to get Virtex6 support.
in that i have used the FFT v7.0. i have made a few corrections and both FFT ant IFFT have started working
1. i was using the run time configurable transform length.
      -the nfft_we should be high for only one clock cycle during which the transform length Nfft is being configured. if Nfft_we is tied to high, it keeps on trying to configure the block and hence the processing never starts.
      -the input data to the FFT block has to be sent with one clock delay after the dynamic transform length is set.
2. though, the dynamic transform length is being used, the transform length that can be chosen in block parameters from the drop down list has to be set at the maximum that u may be using. the dynamic length can be for setting any size smaller than the transform length in the block parameters only.
with these 2 modifications, the FFT started to work.
3. for the IFFT, i have noticed that the output of FFT seems to saturate the IFFT and hence was not giving me results. so i did the 1/N scaling after the FFT and havethen passed the data to IFFT. due to this scaling, the IFFT also started working
Aarunya
swain168
 The output  of 1024 point FFT
swain168
The output of 1024 points IFFT
Could you help me ?
pjayav
hi,
     me too having the same problem. Did u got solution for your problem. If so, please share with me
Thanks & regards
selvam
aarunya
I am having that problem too.
I have also noticed that my FFT output from Matlab and output from Sysgen do not match properly.
aarunya
syoma
Can you post your model as MDL file? It is too hard to analyze without knowledge of all block parameters.
ywu
If you are asking about IFFT, please take a look at this blog: http://myfpgablog.blogspot.com/2009/11/ifft-in-system-generator.html
aarunya
Cheers,
Jim
aarunya
thank you syoma. The FFT is solved. but my IFFT is not solved.
I'll look into the blog which Jim is refering to and if i can't solve, I'll get back.
thank you.
aarunya
Thank you Jim.
I'll check that
farshade
thank you.
Can you please tell me how you solved the mismatching outputs for FFT between MATLAB and SysGen?
I appreciate if you attach the working .mdl file.
Thanks a lot.
aarunya
um hi,
Aarunya
akilan
Thanks a lot for the solution
king1
Hi Aarunya,
Can you please mail me the solution for FFT_IFFT model. I require it urgently. My email id is vikrantmahajan.iitkgp@gmail.com.
Thanx in advance.
ywu
Check http://forums.xilinx.com/t5/DSP-Tools/FFT-IFFT-famous-problem/m-p/193978#M4856
@king1 wrote:
Hi Aarunya,
Thanx in advance.
Cheers,
Jim
