Anonymous
Not applicable
Xilinx AccelDSP 11
Hello world;
I have a problem with Xilinx AccelDSP 11, I reintalled System generator with  AccelDSP 11.1 many and many times but for AccelDSP i have the same message : libSecurity.dll not found.......please help me.
Re: Xilinx AccelDSP 11
It's probably an issue in your environment settings. Check to make sure that the environment variable XILINX points to where your ISE is installed, and %XILINX%\bin\nt and %XILINX%\lib\nt are added to the PATH.
XILINX=<where your ISE is installed>
PATH=%XILINX%\bin\nt;%XILINX%\lib\nt;<other paths>
