utkarshgpt71
Xilinx Picoblaze Assembler not running in MATLAB
whenever I try to run the picoblaze assembler using xlpb_as command in the MATLAB command prompt (in order to generate a .m file from a .psm file), I get the following error:
>> xlpb_as -p control.psm -v 2
Error using xlpb_as (line 33)
C:/Users/utk/Documents/MATLAB/control.psmerror: couldn't run wrapkcpsm2.bat
m7888
I had this issue only in VIVADO. In ISE there was no problem.
One work around is to edit the xlrunperl.m mfile. It is located in your VIVADO directory, somewhere like this:
C:\Xilinx\Vivado\2017.4\scripts\sysgen\matlab
Follow the instructions below. I hope this would help:
1) First you need to install Xilinx ISE 14.7 (the most difficult part)
2) Open xlrunperl.m file and find the following lines:
     perl_exe = xilinx.environment.getpath('ise', 'exe', 'xilperl')
     sysgen_dir = xilinx.environment.getpath('sysgen')
     scripts_dir = xilinx.environment.getpath('sysgen', 'script')
3) Replace them with these new lines (use your own installation directory)
      perl_exe    = 'C:/Xilinx/14.7/ISE_DS/ISE/bin/nt64/xilperl';
      sysgen_dir  = 'C:/Xilinx/14.7/ISE_DS/ISE/sysgen';
      scripts_dir = 'C:/Xilinx/14.7/ISE_DS/ISE/sysgen/scripts';
florentw
Hi @m7888,
Our Community Help has a tip that might help you : Tip: If the message is older than 6-12 months, please post a new message rather than adding to the existing thread. Your inquiry will have a better chance of being picked up by an expert if it is a new topic.
https://forums.xilinx.com/t5/help/faqpage/faq-category-id/posting#posting
I would suggest you create a new topic on the appropriate board
Florent
m7888
Hi florentw,
Thanks for the tip :)
Yours,
Mohammad
