Xilinx blockset missing in Simulink
I am using ISE 14.7 and Matlab 2013a in Windows 10, 64-bit.
I configured Matlab 2013 in "System Generator Matlab Configuration" tool, and it showed "Configured". After running System Generator, an error message popped up saying "Could not find library "xbs_r4" specified in C:\Xilinx\14.7\ISE\sysgen\ids\bin\slblocks.m" In Simulink library, I could not find all Xilinx blocksets.
Is there a way to fix this problem?
Thank you,
Fei
baijiaoni
The default xbs_r4 file under C:\Xilinx\14.7\ISE\sysgen\ids\bin\ is called xbs_r4.mdl.r2010b or with some other suffix. You have to change the file name to xbs_r4.mdl. It works for window 10 OS.
It works for me. I hope it also works for you.
xud
fei.wang@aero.org
I don't think Sysgen 14.7 supports windows 10 machine, please see https://www.xilinx.com/support/answers/17966.html
it only supports Windows 7 and XP for windows machine.
System Generator for DSP 14.7
Operating System Support:
  • Windows 7 Professional
  • Windows XP Professional
  • Windows Server 2008 (64-bit)
  • Red Hat Enterprise 6 Workstation
  • Red Hat Enterprise 5 Workstation
  • SUSE Linux Enterprise 11
  • Support for 32-bit and 64-bit on all OS
baijiaoni
Thanks a lot. It worked.
