Dumbed-down model attached, and a dumb question...
With write enable high, and read-after-write, I see the correct number (a constant) at the SP RAM output that I am trying to store for each of the 100 registers. However, with write enable low, the register contents are still those of the initial value register. What am I missing, and if this was a latency problem (as sometimes suggested in the forums), why does the read-after-write look okay?
