can anyone help me in implementing cross correlation in verilog or vhdl or give some code
hi,
can anyone help me in implementing cross correlation in verilog or vhdl or give some code.i cn't find any woring on it
majidshah353@hotmail.com
Re: can anyone help me in implementing cross correlation in verilog or vhdl or give some code
HI
have a look on wikipedia,
cross corelatino is easy,
  You have two vectors of numbers, one the input, one the correlation.
 Now this is from old memory so plkease check,
You reverse the input vector
  then multiple all the corelatino against the first lot of the input, and add together.
     the answer goes in bin 0,
you then slide the corelatoin one down the input, and reeate, but the addition goes into bin 1,
    contiunue,
how about the auto correlation? did i need to use the cordic ip core to help me doing that?
No you do not need CORDIC for either cross-correlation or auto-correlation.  The correlation is very similar to FIR filtering, the difference is the reference waveform (the coefficients) are reversed for correlation relative to the order they are presented for FIR filtering.  For auto-correlation, the signal is also the reference so you need to cycle the reference coefficients to make it work, but the structure is still basically an FIR filter.
I saw the data sheet of the fir filter IP core  the formula of the single rate FIR is similar to the cross correlation but not the same...
It is the same except the order is reversed.
FIR filter is Y(k) = X(k)C0 + X(k-1)C1 + X(k-2)C2 + ... + X(1)C(k-1)
Correlation is
Y(k)=X(0)C(0) + X(1)C(1) + ....+ x(k)C(k)
I took a sin wave block and took the coefficients of them and made and reversal of those coefficients and used them in fir complier as coefficients and then connected the same sine wave block to fir complier and was not getting the output . it is always showing zero.
please help me
waiting for your reply
  mahadev
Instructor
Instructor
please help me
  mahadev
Please stick to one thread for a single topic.  This is the 3rd thread to which you've posted the same problem, making it difficult for others to read and respond.
- Bob Elkind
SIGNATURE:
Summary:
