kardec
default_clock_driver and xlpersistentdff. What are they used for?
Hello all,
Everytime I convert a System Generator circuit into HDL code, it creates 3 modules.
1- The module of the circuit.
2- A module called default_clock_driver
3- A module called xlpersistentdff
What are this two modules used for? It seems they have no functionality.
nathanx
Sysgen manages the clock implicitly, it does not have the DCM/PLLs, in order to get different blocks running at different rate, it uses clock enable, default_clock_driver is the module generated by the tools which controls the rate of all the blocks in the design by using the clock enable.
