Participant sauvagya30
elf generation error
the .elf in the path "zed_boardupdate/xilinx_dnndk_v3.1/ZedBoard/samples/inception/model" is working fine.
but  i tried to use dnnc_ZedBoard.sh in "zed_boardupdate/xilinx_dnndk_v3.1/host_x86/models/caffe/resnet50"
to generate .elf and then used it to generate resnet50 by using make command this error came:
~/zed_boardupdate/xilinx_dnndk_v3.1/ZedBoard/samples/sdk$ source environment-setup-cortexa9t2hf-neon-xilinx-linux-gnueabi
sahoo@sahoo-Veriton-M4630G:~/zed_boardupdate/xilinx_dnndk_v3.1/ZedBoard/samples/resnet50$ make
mkdir -p /home/sahoo/zed_boardupdate/xilinx_dnndk_v3.1/ZedBoard/samples/resnet50/build
arm-xilinx-linux-gnueabi-g++ -c -O2 -Wall -Wpointer-arith -std=c++11 -ffast-math -mcpu=cortex-a9 -mfloat-abi=hard -mfpu=neon --sysroot=/home/sahoo/zed_boardupdate/xilinx_dnndk_v3.1/ZedBoard/samples/sdk/sysroots/cortexa9t2hf-neon-xilinx-linux-gnueabi /home/sahoo/zed_boardupdate/xilinx_dnndk_v3.1/ZedBoard/samples/resnet50/src/main.cc -o /home/sahoo/zed_boardupdate/xilinx_dnndk_v3.1/ZedBoard/samples/resnet50/build/main.o
arm-xilinx-linux-gnueabi-g++ -O2 -Wall -Wpointer-arith -std=c++11 -ffast-math -mcpu=cortex-a9 -mfloat-abi=hard -mfpu=neon --sysroot=/home/sahoo/zed_boardupdate/xilinx_dnndk_v3.1/ZedBoard/samples/sdk/sysroots/cortexa9t2hf-neon-xilinx-linux-gnueabi /home/sahoo/zed_boardupdate/xilinx_dnndk_v3.1/ZedBoard/samples/resnet50/build/main.o /home/sahoo/zed_boardupdate/xilinx_dnndk_v3.1/ZedBoard/samples/resnet50/model/dpu_resnet50_0.elf -o /home/sahoo/zed_boardupdate/xilinx_dnndk_v3.1/ZedBoard/samples/resnet50/build/resnet50 -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -L/home/sahoo/zed_boardupdate/petalinux_zed/images/linux/sdk/sysroots/cortexa9t2hf-neon-xilinx-linux-gnueabi/usr/share/OpenCV/3rdparty/lib -lopencv_stitching -lopencv_superres -lopencv_videostab -lopencv_aruco -lopencv_bgsegm -lopencv_bioinspired -lopencv_ccalib -lopencv_dpm -lopencv_face -lopencv_photo -lopencv_fuzzy -lopencv_hfs -lopencv_img_hash -lopencv_line_descriptor -lopencv_optflow -lopencv_reg -lopencv_rgbd -lopencv_saliency -lopencv_stereo -lopencv_structured_light -lopencv_phase_unwrapping -lopencv_surface_matching -lopencv_tracking -lopencv_datasets -lopencv_plot -lopencv_xfeatures2d -lopencv_shape -lopencv_video -lopencv_ml -lopencv_ximgproc -lopencv_calib3d -lopencv_features2d -lopencv_highgui -lopencv_videoio -lopencv_flann -lopencv_xobjdetect -lopencv_imgcodecs -lopencv_objdetect -lopencv_xphoto -lopencv_imgproc -lopencv_core -lhineon -ln2cube -ldputils -lpthread
/home/sahoo/zed_boardupdate/xilinx_dnndk_v3.1/ZedBoard/samples/resnet50/model/dpu_resnet50_0.elf: file not recognized: file format not recognized
collect2: error: ld returned 1 exit status
Makefile:75: recipe for target 'resnet50' failed
make: *** [resnet50] Error 1
Thanks and regards
Sauvagya
Re: elf generation error
please find attached an Answer Record that should go public soon. There is a section explaining how to build the Resnet50 for ZedBoard. Let me know if you find difficulties. I am still reviewing it and there are some redundancies but I hope it will make the porting to ZedBoard easy
Thanks a lot for providing this document.
can you please send me the link from where I can download Resnet50_ZedBoard.zip
sauvagya
Hi @sauvagya30 ,
By the way are you compiling the appication on the Zedboard? If so have you enabled the packagegroup-petalinux-self-hosted?
I was told that this should work for set up a board compile environment.
Best Regards,
Jason
Dear Jasonwu,
I am using zedboard, but did n't enabled  the packagegroup-petalinux-self-hosted.
let me try and i wants to know doed zedboard support VGG 16.
 Sauvagya
I received the desired .zip.
Thanks a lot
Best Regards
Sauvagya
Dear gguasti,
every thing what u have send is working properly.
when i wants to add some extra pin in .xdc file then following error is encounter.
set_property LOC F22 [get_ports {sel}];
set_property IOSTANDARD LVCMOS33 [get_ports [sel] ];
error: Command 'select_objects' is not supported in the xdc constraint file.
can you please address this
Best regards
Sahoo
