floating point IP logicore: accumulator
I costumized the floating point logicore IP as an accumulator . Then I simulated the HDL wrapper.
The problem is that I can't reset the result ( whatever the forced aresetn is):
*  the reset "aresetn" <= '1':
 *  the reset "aresetn"<= '0'
mariem_@fsm.12-34 how did you configure the IP ? Maybe it's possible to configure it without needing a reset?
i have run the HDL wrapper simulation, but no accumulation work , even the reset doesn't work. Here is a capture screen.
Best regards.
Tags (2)
