floating point division using ip cores.
I am sriharsha.S
I am using IP coresfor division.
I want to use floating point divider.
I used a 32 bit A, B.
i am using 28 bits for exponent and 4 bits for fractional part.
The RESULT=A/B.
i used A = 30000
            B=180
But, i am not getting the answer correctly.
Can any one help me???/
Re: floating point division using ip cores.
A couple of things are mixed up here:
The latest version of floating point core is v5.0, not 3.0
The floating point core works with floating point numbers, which is an IEEE standard ( http://en.wikipedia.org/wiki/Floating_point ). You need to convert your inputs to that format and convert the output back to a human readable decimal.
@santhapurharsha wrote:
Hi ,
i am using Xilinx divider core 3.0,
It is a divider.
Open FLOATING point CORE,
and there, u will find many operations, in which divider is an opertation.
I used that core.
i will attach a data sheet/ pdf even about that core.
Please find it..
Cheers,
Jim
Advisor
Advisor
What's the answer you're getting? What were you expecting?
I am using 16 bit exponent width , 4 bit fractional width.
I am attaching  my code and test bench.
I am using version 13.1.
i will also attach the rsult.
Please help me.
I have given input as a=18000, b= 230.
Bu t wat all i got the result is not wat we expect.
code
`timescale 1ns / 1ps
module divflt1(input clk,
                        input [19:0] div,
                       input cen,
                      input  [19:0] den,
                             output   flow,
                         output redy,
                         output  [19:0] out
fltcore uut (.a(div),
                 .b(den),
                  .clk(clk),
                   .ce(cen),
                    .result(out),
                      .overflow(flow),
                       .rdy(redy));
endmodule
test bench
module divflt2;
// Inputs
reg clk;
reg [19:0] div;
reg cen;
reg [19:0] den;
// Outputs
wire flow;
wire redy;
wire [19:0] out;
// Instantiate the Unit Under Test (UUT)
divflt1 uut (.clk(clk),
.div(div), .cen(cen),
 .den(den),
 .flow(flow),
.redy(redy),
 .out(out));
initial begin    // Initialize Inputs
 clk = 0;
 div = 0;
 cen = 0;
 den = 0;
// Wait 100 ns for global reset to finish
#100  clk=1;
      cen=1;
     div=18000;
      den= 230;
 // Add stimulus here
end
  always begin
#5 clk=~clk;
end
endmodule
The result image is attached...
Advisor
Advisor
Which core are you using? It doesn't look like the Xilinx divider core 3.0, since that has two outputs (quotient and fractional), or 4.0 (AXI4 interface).
Please give us *all* of the information we need to investigate your problem.
Hi ,
It is a divider.
I used that core.
Please find it..
Please use the code and testbench that  i have provoded and run the simulation.
U wil get the same result as i have shown in the attachment earlier.
Use the floating point divider core only.
Dont use the general divider core.
The general core  divider have two outputs, where as the floating point divider have only one output. PLEASE  find that also..
Thanks...
Advisor
Advisor
Thanks for the additional details.
The floating point divider core uses floating point inputs. You still have not stated what the result you're expecting is. If you're expecting an answer of 30000/180 = 166.67, then your inputs are wrong. Your test bench assigns them as if they were integers, but they are actually floating point numbers following your 16+4 scheme.
I'm not confident I've converted it properly, but integer 30000 corresponds to 2^-7 + 2^-8 + 2^-9 + 2^-10 + 2^-12 + 2^-15 + 2^-16 = .01493835449218750000
180 is .00785541534423828125
Divide these two, and I get 0.24863421148476387034
Converting your UUT's output to floating point and I get.. 1.90166322690299866456.
Well, my sums may be completely wrong here, and I'm in a hurry to knock off for the weekend, but hopefully you get the idea of what the problem is.
If you think I've misinterpreted the problem, please tell us exactly what output you're expecting, and why.
Hi ,
It is a divider.
I used that core.
Please find it..
Cheers,
Jim
Thank you.. :)
