shreyassg13@gmail.com
fraction arithmetic
I am implementing CORDIC algorithm, in one paper they have used fixed point arithmetic, I wanted to know how to do +,-,*,/ operations in this representaion. is this the best or floating point is better?
hwneff
to answer your last question about whether to do integer or floating point requires
  a lot more information about what you need and how fast you need to compute
   that which you need.
based, however, on your initial comment about fixed point,  i would suggest you
   should investigate something called "q notation" -- a convention that uses
   integer-ish numbers and functions to operate on "fractions".
NB: the word "convention" -- it is just that: whether the binary digit sequence
   "10000000" is 127 or 1 or 0.5 is all a matter of how one has chosen to look at it.
for starters, have a look at wikipedia:
http://en.wikipedia.org/wiki/Q_%28number_format%29
once you have the technique, then revisit those cordic papers and, if appropriate,
   revisit your problem to determine the apporpriate values and ranges to be using
   as you apply what you've learned.
bassman59
Historian
Historian
@shreyassg13@gmail.com wrote:
It depends on your application's requirements.
hwneff
