how to generate 4 MHz clock from 2 MHz clock in FPGA.
I need to generate 4 Mhz clock from 2 MHz clock . I checked clocking wizard/MMCM/PLL , but there input clock range start from 10 MHz.
I had read about using rising and falling edge detectors but they fail to give 50% duty cycle.
can DDS(direct digital synthesizer ) convert 2MHz clock frequency into 4MHz frequency??
what are the other methods to do that??
Ankit
Re: how to generate 4 MHz clock from 2 MHz clock in FPGA.
Hi @ankitkes2
Solution in the below post seems appropriate.
https://forums.xilinx.com/t5/Synthesis/how-to-generate-4-MHz-clock-from-2-MHz-clock-in-FPGA/m-p/1074777#M34202
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
