importing system generator ip in vivado ip catalog
I have successfully created system generator ip and apparently successfully imported it in Vivado
Should this IP give same results as system generator simulation or do I need some modifications for it
Best Regards
Uzmeed
If you run simulation using the IP imported from sysgen, you should get the same results with sysgen simulation.
What if I use it in the synthesis and implementation
Uzmeed
Thanks for the update and quick reply. I'll be sure to keep an eye on this thread.
It is also good if you use it in the synthesis and implementation.
@nathanx Thank you
So you mean I should go for it with confidence
uzmeed
Yes, you can. Take a look at "Importing a System Generator Design into a Bigger System" on UG897. Hope it helps.
