Visitor kids998
install Viterbi Core license problem
When I run  systen generator , always have" You must install the Viterbi Core license in order to use this block in hardware.
Error occurred during "HDL Netlist Configuration".
I follow  http://www.xilinx.com/ipcenter/ipevaluation/viterbi_evaluation.htm setp and get  email with  Xilinx.lic file
then,what can I do,it doesn't work
please help me
Message Edited by kids998 on 02-21-2010 10:31 PM
Visitor dreamrun
Re: install Viterbi Core license problem
Have you sovled your problem? I have the same problem. If you have some methods to solve it, pls tell me. Thank you.
Newbie 400440
Visitor rhearty1
I'm suffering from this problem right now. I've installed the hardware evaluation license, confirmed it in Xilinx ISE, even generated a core in ISE for that block. But still, System Generator is not getting the allowance from ISE to use the license. What's the solution?
What versions of Sysgen are you using?
What OS?
When you run xldiagnostic from the matlab console is the Viterbi license found?
Visitor rhearty1
What OS?
Using Sysgen with Matlab 2012b, configured with ISE 14.3.
OS is 64-bit Windows 7 (Home Premium)
There's only a command 'xlDiagnosticInfo', if that's what you meant. When I run it, the following is output to the command window:
>> xlDiagnosticInfo
Starting xlDiagnosticInfo
Output file:C:\...\xilinx_diag_output.txt
Gathering System Information with xinfo ...
Invoking xinfo...
I then check the xilinx_diag_output.txt and it contains this:
Error running xinfo
'xinfo' is not recognized as an internal or external command,
operable program or batch file.
I wasn't surprised. By now I'm used to things not going so smoothly in System Generator. Is there any other way to find out what licenses System Generator knows about?
Are you using Viterbi v7.0 (non AXI) or v8.0 (AXI)? There is a known issue with SysGen not getting correct license for Viterbi v7.0 core. Use v8.0 instead.
@rhearty1 wrote:
What OS?
>> xlDiagnosticInfo
Invoking xinfo...
Error running xinfo
Cheers,
Jim
Visitor rhearty1
I actually was using v8.0, that's when I got the problem. I switched to v7.0 and I had no license error.
It would be nice to know what licenses System Generator sees. Is there any way to get around the xinfo error mentioned above?
Ryan
