integration with sysgen fdatool
Hello all,
When using FIR Compiler 7.2 on sysgen im getting this error while trying to use the - "xlfda_numerator('FDATool')" import of coefficients  :
how can i resolve this matter and use the xlfda_numerator('FDATool') import ?
Thanks for the help,
Daniel
Re: integration with sysgen fdatool
This is not the bug. This kind of error pops up when extra spacing in coefficients. Just try to remove extra space and regenerate the core/block. please share the test case
check this one known issue
https://www.xilinx.com/support/answers/68669.html
Thanks and Regards
Balkrishan
not the same issue
but thanks
Please use following functions to figure out the maximum and minimum coefficient value generated by FDATool :
max(xlfda_numerator('FDATool'))
min(xlfda_numerator('FDATool'))
Also check the coef width setting in FIR. From the error message, it seems the xlfda_numerator('FDATool') value is out of range. Please try to increase coef width, and see if it helps
