Marta
makefile: 27: recipe for target 'lib's.a' failed
I build Emulation-AIE and got the following error. Please kindly advise.
Thank you.
Tags (3)
florentw
Hi @Marta
It seems that you still miss input files:
error: no such file or directory: '/home/xilinx/training/design_files/design_files_Marta/step1/Emulation-AIE/./copy_in_out.cc'
error: no such file or directory: '/home/xilinx/training/design_files/design_files_Marta/step1/Emulation-AIE/./fir_32t.cc'
Make sure all your include paths are correct
Florent
florentw
Hi @Marta
Florent
Marta
Hi Florent,
Thank you for your help. It works now.
