walkerata
mex error in Xilinx system generator w/ comm toolbox blocks
Short and sweet ...
Vivado 2017.3 system edition
MATLAB R2017a
Reed-solomon encoder/decoder 9.0 blocks
I am launching system generator correctly. Other models without these blocks compile and run properly. I can place the Reed-solomon blocks in a system generator model, but when I click on one in order to configure it, I receive the following error:
'Unexpected unknown exception from mex file..'
This error occurs whenever I attempt to configure any aspect of these blocks. Other blocks in the communication blockset generate this error as well (Viterbi, for example).
Any ideas?
Thanks!
walkerata
I've now reproduced this problem on two separate installations of System Generator (2017.3, MATLAB 2017a).
Any ideas? Pretty clear a reinstall won't fix the problem.
