migrating project from Plan Ahead to Vivado
I have a very old H/W project (~2012) that was done using Plan Ahead.  It was a project using the Zynq 7000 and based heavily on the zynq-702 dev platform.  It exported a system.xml file for the SDK.
I want to migrate/convert the H/W project into a Vivado project so I can (re)export the H/W files as .HDF.  Then, generate a a new BSP and get the S/W application code built and running in this codeflow.
I was hoping to just find a utility to convert an xml to hdf, but it doesn't seem to exist.  So I'm taking this other route.
Questions...
- is there a document/video/tutorial that shows how to take a project created in Plan Ahead and get this into Vivado?  I can read in the project into Vivado, but it doesn't build anything and reports lots of errors.  And I don't see any block diagram of the PS7 sub-system.  Seems it was done all with verilog files (could it be in a file called xil_defaultlib.system)?  Does that make sense?
- maybe what I need to do is create a new Vivado project with the PS7 subsystem replicated using the block diagram? Then add the vhd files?
- is there a service whereby we can provide all the old H/W files and Xilinx (or other vendor) can migrate into Vivado 2018 or 2019?
Re: migrating project from Plan Ahead to Vivado
Hello james.hansen@teaminc.com
I have provided a link to UG911, which will help you through how to convert your ISE project to Vivado. I have also provided a forum post similar to yours, which might be of use.
UG911: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug911-vivado-migration.pdf
Forum: https://forums.xilinx.com/t5/Welcome-Join/Migrating-from-ISE-to-Vivado/td-p/636956
I hope this helps!
The link to the similar issue isn't much help, it just references the same ug911 PDF.  But let me spend some time reviewing the PDF and I will respond again.  thank-you.
The ug911 PDF is somewhat helpful.  I can open the .ppr file and create a new vivado project.  I can see a UCF file that needs to be converted.  But as a first step want to create a block diagram of the PS7 that is on the Zynq xc7z020clg400 part.  What currently exists is a file named system_stub.vhd.  The Vivado project doesn't like this file:
[DRC INBB-3] Black Box Instances: Cell 'system_i' of type 'system' has undefined contents and is considered a black box. The contents of this cell must be defined for opt_design to complete successfully.
So I *think* what I need to do is convert this to a Block Design.  Is there some guidlines for doing this?  I think I will remove the system_stub.vhd file and instead have a design_1.bd file that contains all the info of the system_stub.vhd file.  Is there specific information about how to do this?  Or can you provide?
