raniaeldeeb
multirate clock options on the xilinx token(system generator)
i am designing a multi rate system on the system generator, i want to operate using a single clock and produce different rates using clock enables,, so i chose in the multi rate implementation options of the xilinx token "clock enables", when i took  the generated vhdl file on the xilinx ise and i formed a schematic symbol i found out that there is three clk inputs for the three different rates i used in my system, why is that?? i thought there will be one clk input and 3 clk enables inputs for my 3 rates???
can anybode suggest what might be the error??? thanks in advance
criley
The machine generated RTL by SysGen can be hard to follow.  Make sure that you are looking a the top-level entity IO "<your_model_name>_cw" declaration and check if there are multiple clocks here.
-Chris
agn
I believe I am having the same issue. It would appear that my top level definition is creating both a second clock and an enable signal to do the second clock rate. The relevant part of the cw.vhd file (I think) is below.
test_x0: entity work.test
port map (
ce_1 => ce_1_sg_x0,
ce_8 => ce_8_sg_x0,
clk_1 => clk_1_sg_x0,
clk_8 => clk_8_sg_x0,
gateway_in => gateway_in_net,
gateway_in1 => gateway_in1_net,
gateway_out => gateway_out_net
Cheers,
Andy
