Visitor sryzdn
open xilinx system generator in windows commendline with opengl
HI,
I have a student version matlab installed on my computer and it does not fully recognizes the graphic card in my computer. So, I normally open matlab in cmd with the following command:
matlab -softwareopengl
Now, I want to install system generator. I want to know if there is any equivalent command for sysgen?
I would be grateful if you kindly help me about it.
Re: open xilinx system generator in windows commendline with opengl
sysgen install with Vivado HLS edition . Sysgen is separate tool and you must have valid license.
please refer installation guide
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_3/ug973-vivado-release-notes-install-license.pdf
To use sysgen you must have valid matlab combination
https://www.xilinx.com/support/answers/55830.html
Thanks and Regards
Balkrishan
Visitor sryzdn
There is no issue with the valid license.
The question is if I can open sysgen in command line to overcome the issue with "opengl". I would be grateful if you answer this question.
you can try
sysgen
or
sysgen -softwareopengl
Thanks and Regards
Balkrishan
Newbie seeleyr
Here's what worked for me:
* launch Matlab and do >>opengl('save','hardware')
* launch sysgen normally
The Matlab command above saves your preference for hardware acceleration such that it doesn't need to be specified at the command line. This should (fingers crossed) be observed when you start sysgen which in turn launches Matlab.
