Visitor ranvi2195
problem in implementing 8 point FFT using FFT V9.0 in system generator
I have implemented 8-point FFT using FFTv 9.0 in system generator and faced the following problem .Can anyone guide me how to rectify that error.
I have attached the .slx and .mat file for reference.
Re: problem in implementing 8 point FFT using FFT V9.0 in system generator
The problem is due to the configuration of the FFT IP in your design.
FFT IP core is using the Radix-4 Burst I/O architecture. The minimum transform size for this is 64, whereas the configured size is 8.
Please refer to the Sysgen flow under the Design flow steps in the PG 109.
Please change the Transform size to greater than 64 if Burst I/O architecture is required else if transform size of 8 is required , consider moving to Radix-2 Burst I/O architecture or Pipelined streaming architecture.
Vivek
