parikshit001
problem on opening Model Composer
I have installed Matlab 2019b & after that Vitis 2019 but while double-clicking the Model Composer shortcut created in the desktop I am not able to get any response. This is happening in both Windows 10 & Ubuntu Operating System. Kindly guide me to resolve it out.
meherp
HI @parikshit001
Are you using windows 64-bit version. The 32-bit version is not a supported version.
What is the Ubuntu version. Below are the supported versions,
Ubuntu Linux 16.04.5 LTS; 16.04.6 LTS; 18.04.1 LTS; 18.04.02 LTS (64-bit).
In windows, can you try to delete the entry of "Matlab and Vivado" in the Task manager; and then run it again.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
ravidapu
I installed Vitis 2019.2 and MATLAB 2019b on Windows 10 and I am able to launch Model composer successfully.
There could be some problem with your installations, please clean up the directories and try re-installing the tools and check
Just launch MATLAB tool and see, if it launches then model composer should also be launched
Regards,,
Raju A.
parikshit001
yes i checked with windows 64bit & ubuntu 18.04 version with 2-3 times of fresh installation but the model composer shortcut link doesn't came with opening a window.
meherp
Hi @parikshit001
Are you able to launch the Matlab and Vivado on your system?
parikshit001
yes. separately matlab & vivado-vitis are all working fine.
meherp
Can you try to run the 'model_composer.bat' file by double-clicking it.
It is available at below location (please replace C:\Xilinx\ with your installation location).
                C:\Xilinx\Model_Composer\2019.2\bin\model_composer.bat
parikshit001
i'm facing the same technical error
ravidapu
Can you try launching the model composer from command line as admin ?
firstly try launching mode composer as below:
c:\Xilinx\Model_Composer\2019.2\bin>model_composer.bat
if it does not work, try below with -vivado switch
c:\Xilinx\Model_Composer\2019.2\bin>model_composer.bat -vivado c:\Xilinx\Vivado\2019.2
Please send us the info, warnings, errors that you see in both the cases
Raju A.
I am facing the same problem.
I tried above process and it says this:
"ERROR: Could not find MATLAB executable in the path. Please add the path to a MATLAB executable to the PATH environment variable and try launching Model Composer again."
'""' is not recognized as an internal or external command,
operable program or batch file.
So I added my Matlab Executable file (.exe) file address into Path variable but it still shows the same error..
Can some help here
a_r_k
I am facing a similar problem. I have Vivado 2020.2 and Vitis 2020.2 installed along with the model composer. On clicking the model composer it does nothing.
I have tried the following commands using the terminal to open the model composer,
D:\Vivado2020\Xilinx\Model_Composer\2020.2\bin\.\xmc_sysgen.bat
Output
WARNING: Could not find a Vitis installation on path parallel to Model Composer.
Please specify the location of a vitis installation with -vitis option.
ERROR: Could not find a relative Vitis_HLS in 'D:/Vitis_HLS2020/Xilinx/Vitis_HLS/2020.2'.
So I specified the vitis location using the following command,
D:\Vivado2020\Xilinx\Model_Composer\2020.2\bin\.\xmc_sysgen.bat -vitis D:\Vivado2020\Xilinx\Vitis_HLS\2020.2
Output
ERROR: Invalid -vitis path 'D:\Vivado2020\Xilinx\Vitis_HLS\2020.2\'.
It is now showing invalid vitis path. Please help!
torid
The path should point to the directory that the executable is, not the executable itself. Can you try to use D:\Softwares\Matlab2019a\bin\ instead of that path with the matlab.exe?
torid
It looks like you're pointing to the Vitis_HLS directory, not the Vitis directory. Can you update it to point to Vitis?
a_r_k
I have Matlab version 2020a and 2020b, both of them are perfectly working.
I couldn't find any vitis directory in the installation files.
I tried with these paths,
D:\Vivado2020\Xilinx\Model_Composer\2020.2\bin>xmc_sysgen.bat -vitis D:\Vivado2020\Xilinx\Vitis_HLS\2020.2
D:\Vivado2020\Xilinx\Model_Composer\2020.2\bin>xmc_sysgen.bat -vitis D:\Vivado2020\Xilinx\Vitis_HLS\2020.2\bin
but still showing invalid vitis path.
torid
Hi @a_r_k , If there's not a Vitis directory, you may have chosen the wrong options during your Xilinx install. This is my 2020.2 install area, and there is a Vitis directory. If you don't have the Vitis directory, you are missing pieces that are needed for Model Composer.
