grottenolm84
problem with non-memory-mapped input ports
Hi everybody,
my next problem with sysgen:
I want to start a hardware-cosimulation with my Xilinx Spartan 3e Starter Kit.
Evertime I try to generate the library with my non-memory-mapped input-ports I get the error message:
Illegal parameterization: location constraints
The number of pad locations must match the number of bits for the
output of this gateway.  The pad locations must be specified as a
cell array, e.g., {'MSB', ..., 'LSB'}.
Error in ==> xilinx_spartan_3e_starter_kit_libgen at 23
ss = add_input(lib, name, width, locs);
Error in ==> run at 57
          evalin('caller', [s ';']);
This only occurs with input ports -output ports can be generated by the s-function.
Perhaps anyone knows a solution for this....
thanks
benchan
Please try the attached script.
Tags (3)
benchan
There is a bug in the libgen script. To work around it, you can modify the script to put the line "set_param ( gcbh, 'LOC', locs );"  after "set_param( gcbh, 'width', width)".
grottenolm84
I think I need some more help at that point.
Where can I find the "set_param( gcbh, 'width', width)"  in my generated libgen_script ?
There are only a lot of set_param(port... and set_param(ss.... lines in the script....
I have attached the generated libgen script
benchan
Tags (3)
grottenolm84
Thank you very much ! Now the script runs perfectly.....
