proplem in execute FBGA build in dspace 1006 its FBGA 5203
when i make execute for FBGA system in the first one it execute done and build it in dspace then when i want to make any change in the system there are an error appear i attach screen shoot of it  i must make a restart to pc to run correctly
Is this a sysgen or DSP IP question?
can you clarify your question?
when i make execute for eny system and build it then when i wanted to make change in it appear an error that attach in figure
Where is the figure? The question is still not clear. Can you provide more details?
