anushakodali
qpsk modulation
suggest vhdl code for QPSK MODULATION AND DEMODULATION.
anusha.
meherp
Hi @anushakodali
Did you try to write the code?
May be it will be good to ask the issues which are you facing in the design (rather than asking for complete code).
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
