"An exception was raised:" in System Generator
 Hello everybody,
I'm trying to  generate System Generator project that includes "dafir v9_0". But I see following error.
I think, error  related on file name which is "distributed_arithmetic_f?r_filter_virtex4_9_0_63c98a9f54cc3efe.coe". Normally I can not create a new file that contains "?", question mark.
I'm using ISE & System Generator 10.1.03 version.
How can we solve this trouble?
Best regards,
Ali
standard exception: XNetlistEngine:
com.xilinx.sysgen.netlist.NetlistInternal: couldn't write D:/calismalar/system_generator/mart/filtre/fir/netlist/sysgen/coregen_qKyT/coregen_tmp/distributed_arithmetic_f?r_filter_virtex4_9_0_63c98a9f54cc3efe.coe at D:\calismalar\system_generator\mart\filtre\fir\netlist\sysgen\masterScript57518.pl line 382
Re: "An exception was raised:" in System Generator
There are a lot of different possible causes of this error message.  Please take a look at answer record 31095 here:
http://www.xilinx.com/support/answers/31095.htm
I would suggest looking for the coregen.log file in the output directory and looking for a more detailed explanation.
