uzmeed
reading fixed point fractional number
I have made an IP that has some register with values in  Q(m.n) format
while debugging I want to read the decimal number but I am unable to convert it successfully to correct number
Please help to find the way that can translate the number correctly in decimal format or any way that I can make two different registers in verilog one for m and other for n
Best Regards
uzmeed
nathanx
Is the "m" here all the bits of one data or just the integer bits? Is the “n” fractional bits of the data?
uzmeed
Hi @nathanx
Yes
joancab
Read your Qm.n as integer, cast it to float and divide it by 2^n
nathanx
@uzmeed , does @joancab's reply answer your question? If it does, please accept it as solution?
