Anonymous
Not applicable
setting for sysgen Explicit Period...
What's the relation between these parameters..And how set them correctly?
1.Simulink system period
2.FPGA clock period
3.System Clock (Mhz)
4.Explicit Period
Just want to make 1Mhz sine wave:smileysad:
another question is that are these just affect in the simulation..Or implementation too!So if these parameters are important for the output result..I have to say that the documentation about dds and sysgen user guide are just bull**bleep**!!Because there is no good information about this problem...
Here is what I have done..So far:
Re: setting for sysgen Explicit Period...
Yes as long as the input clock to your FPGA is 100MHz.
Cheers,
Jim
Anonymous
Not applicable
by these parameterer:
fpga clock period =10 ns
simulink system period=10e-9
.......dds:
system clock =100Mhz
desired output=1Mhz
explicit sample period=0.00000001
and after more than 15min of simulation!!!! I got this:is that true?should it be take so long...am I right?:manmad:
Please take a look at this blog: http://myfpgablog.blogspot.com/2010/07/dds-in-system-generator-how-to-set-up.html to see if it helps.
2.FPGA clock period
4.Explicit Period
Cheers,
Jim
When you run simulation, there is an one time initialization of DDS every time you change any parameter on the block. The initialization can take long time (sometimes painfully long). If you run simulation the 2nd time with the same parameters, it should be a lot faster.
Good news is that 12.2 (coming soon) has big improvement on the speed. I highly recommend you upgrade to 12.2 if possible once it's released.
.......dds:
desired output=1Mhz
Cheers,
Jim
Anonymous
Not applicable
thanks a lot abou the link and your response...
would you please tell me if these seeting are correct to implement on FPGA for making a 1Mhz sine wave ?
.......dds:
desired output=1Mhz
explicit sample period=10e-9
are these parameters correct?
in your blog ,test 1 and test 2 are not real 1Mhz ? test 1 is:10mili Hz
test 2 is 100mili herz...
Yes, your settings will get you a 1MHz sine wave.
Regarding results from test1 and test2: when you use simulink for digital signal processing, everything is sample based. You will find it a lot easier to think everything in terms of samples or clock ticks instead of MHz or any other time/frequency unit in Simulink. The absolute value you use for the simulink system period doesn't really matter. Once you choose a value, everything else will be scaled based on the simulink system period.
In test1, simulink system period is 1 (1Hz if you will)  = 100MHz in FPGA => 10miliHz in simulink = 10e-3*100e-6 = 1MHz
In test2, simulink system period is 0.1 (0.1Hz if you will)  = 100MHz in FPGA => 100miliHz in simulink = 100e-3*0.1*100e-6 = 1MHz
.......dds:
desired output=1Mhz
Cheers,
Jim
Anonymous
Not applicable
Oh,tnx a lot for your response,
as my parameters takes very long to simulate..So for example if I use the test1 parameters,and then implement on Fpga,do I get real 1 Mhz sine wave?
Cheers,
Jim
Anonymous
Not applicable
ooook,thank you very much:smileyhappy:
Hi!
how schould i change this frequency to get another output frequency or more than one output frequency? for example iam trying to generate i thre signals 80, 85 and 90 MHZ.
i thank u for ur help
