01-13-2021 05:24 AM
inside an AI Engine Tile, there is a 32b Scalar RISC Unit.
There is support for sqrt, inv, and invsqrt integer functions.
Is there hardware support for these functions or are they fully emulated by RISC instructions?
i guess that in the latter option, i couldn't start (i.e., pipeline) a new function, until the current function call is finished.
Is there somewhere mentioned, how many clock cycles these functions would approximately take?
Best wishes,
jarno
01-13-2021 06:24 AM
The cycle counts for various AI Engine Scalar processor commands are listed in Architecture Manual AM009.
https://www.xilinx.com/support/documentation/architecture-manuals/am009-versal-ai-engine.pdf
See chapter 4, page 49-51 for details.
Note that the document update for 2020.2 is under review so check for new releases on xilinx.com or Xilinx Doc Nav.
01-13-2021 06:24 AM
01-13-2021 07:14 AM
and thanks for quick response! Actually, they are fast operations taking only 4 clock cycles!
Best wishes,
jarno
01-13-2021 08:00 AM - edited 01-13-2021 08:01 AM
Plus one cycle for fix2float and float2fix each, as most likely you're working on fixed point numbers.
