sqt function required for rms calculation
i want to calculate rms values of some signals.
xrms = sqrt{ 1/n*( x_1^2 + x_2^2 + ...... + x_n^2 ) }.
but the problem is sqrt operation. i have used cordac but it does not gives precise values u can either give integers or fractions. I have also tried sqrt function from fixed_alg_ug pkg but its not synthesizable because it depends on real_math pkg.
i need a sqrt code which can give me precise answer for example
when 48 goes to => sqrt => gives 6.928 => not 7
Haider
use cordic for sqrt function.
www.xilinx.com/products/intellectual-property/CORDIC.htm
Cordic supports these functions
Feature Summary
• Functional configurations
° Vector rotation (polar to rectangular)
° Vector translation (rectangular to polar)
° Sin and Cos
° Sinh and Cosh
° Atan
° Atanh
° Square root
Thanks and Regards
Balkrishan
Instructor
Instructor
Suggest you post this problem to the IP forum.  This has nothing to do with Design Entry or FPGAs.
-- Bob Elkind
SIGNATURE:
Summary:
Moved this to IP board
Deepika.
Deepika.
Feature Summary
° Sin and Cos
° Sinh and Cosh
° Atan
° Atanh
° Square root
Thanks and Regards
Balkrishan
