system generator does not find the matlab installation path
Hello every one,
If I start the "system generator 2019.1 Matlab configurator" as admim I could not see a Maltab Version installed on my computer.
When I push the button "Find MATLAB" I could choose the directory to MATLAB 2017b but I get the following meassage "The path you supplied is not a valid MATLAB path or has already been added."
The path I selected is also set in the environment variable "path". Matlab is installed on my computer under "C:\app\maltab\..." (the path has no space, dot, ...)
Thank you!
regards
Newbie hptech-com
Re: system generator does not find the matlab installation path
But if their application cannot be implemented with standard Xilinx System Generator is an easier way to implement DSP algorithms in FPGAs than HDL, and a natural path for algorithms already designed in MATLAB.
HI @stefan.schwemmlein ,
Please refer to forum post : https://forums.xilinx.com/t5/DSP-IP-and-Tools/MATLAB-support-for-2019-1-is-misleading/td-p/1020843
XSG 2019.1 supports Matlab R2018a, 2018b and R2019a officially.
