kashyap
viterbi decoder
I am using viterbi decoder for constraint length of 9 and 1/3 decoder. My packet to decoder is of 72 bits only. My traceback length is 12. I am not getting the output of decoder.
nathanx
Can you take a look at XAPP551? https://www.xilinx.com/support/documentation/application_notes/xapp551.pdf
If you do not know the initial state of trellis and traceback,  tail biting and Packet Contains Multiple Traceback Lengths may be suitable for you.
nathanx
