play_emma
wavescope
when I double click the waveform  try to show WaveScope analog signal sometimes,and it will not react at another time. i must use ise14.7, system is win7 x64 and matlab2013b,how to slove this bug?
nathanx
The question is not very clear, can you attach your sysgen model or add some screenshots to show the issue?
play_emma
Thank you very much your reply! maybe is matlab2013b bug, this problem sometimes happens, sometimes it does not.
