xfft_v8 bit accurate c model does not compile with MEX in Matlab
Hi Everyone,
I have to use the xfft_v8 model from coregen in my design. For this purpose, I need to creat bit true verification model using the bitaccurate c model provided along with the core from coregen. As I am  making the verification model in matlab , I need to use the mex compilation of the cpp code in matlab. As mentioned in the document "xfft_bitacc_cmodel_ug459.pdf " page number 19, I executed the make_xfft_v8_0_mex.m file in the directory , which did not go through because of an error whose screen shot I have attached below . My gcc version installed is GCC version 5.1.0 (tdm64-)
Please help to figure out why am I getting the error and how to overome the error.
@rcst201427420m
Make sure all the files (including the .lib files) are in the current path.
Check on the Mathworks to get to know the compilation tools for your Matlab and OS.
