xlSysgenGUI('startup',gcs,gcbh);'
Hi ,
i got error  callback string is xlSysgenGUI('startup',gcs,gcbh);' ,  while generating IP_catelog from system genrator token .
kindly assist to remove this error .
Avns
回复: xlSysgenGUI('startup',gcs,gcbh);'
What's the full error message? Do you encounter the error with each sysgen model?
