An error occurred when I use commend 'decent_q qunantize ' of DNNDK
version:: dnndk3.1 gpu/cpu(same error) network model:: yolov3 tensorflow error:: INFO: Checking Float Graph... INFO: Float Graph Check Done. INFO: Calibrating for 17 iterations... 100% |#####################################################################################################################| INFO: Calibration Done. INFO: Generating Deploy Model... [libprotobuf FATAL external/protobuf_archive/src/google/protobuf/map.h:1058] CHECK failed: it != end(): key not found: value terminate called after throwing an instance of 'google::protobuf::FatalException' what(): CHECK failed: it != end(): key not found: value ./decent_q.sh: 行 10: 16467 已放弃 (核心已转储) decent_q quantize --input_frozen_graph ./freeze/conv_yolov3_InsulatorBolt.pb --input_nodes input/input_data --input_shapes ?,416,416,3 --output_nodes conv_sbbox/BiasAdd,conv_mbbox/BiasAdd,conv_lbbox/BiasAdd --input_fn graph_input_fn.calib_input --method 1 --gpu 0 --calib_iter 17
