Are there some IO pins that I can controlled in Linux image
I have successed to download xilinx-zedboard-dnndk3.1-image-20190812.zip and flash it into my zedboard
Now I want to control the PMOD header in the zedboard,dose the image have drivers to contorl it or I should intall a driver by myself.
Or are there any drivers that had been installed in the image to controlled IOs or expansion headers ? I want  to communicate with another board/PC.except  for host PC .
Re: Are there some IO pins that I can controlled in Linux image
Hi lijinghaiwhu@gmail.com ,
You need to check the PCB design and check if there are any connections between your target PMOD and Zynq IO pins.
If so you can use Zynq PS GPIO to control the pins you found. MIO for PS pins EMIO for PL pins.
You can find driver and example here:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842398/Linux+GPIO+Driver
Or if you like you can choose axi_gpio for PL pins.
And BTW I would say that the Zedboard is an ANNET board. You may find useful information like PCB schemetics from ANNET website.
Best Regards,
Jason
Best Regards,
Jason
Thanks a lot! Your answer did help me a lot. I checked the  PCB schemetics , as you said ,it has such connections.
I checked the image in xilinx dpu website, I found gpiochip906 in /sys/class/gpio/ . So what is the available gpio number? And to which pin it connects?
You may need to caculate the value according to your IPI design here.
In the WIKI page I have mentioned before there is an external linked webpage:https://lkml.org/lkml/2014/7/7/390 you can refer to.
If you can find an output pin like an LED or even using a oscilloscope it would be easier to check the result.
Best Regards,
Jason
Thanks for your reply. I finally understood it when I saw this Q&A.
Post here if anyone have same question as mine.
https://forums.xilinx.com/t5/Embedded-Linux/GPIO-mapping-of-Zynq-on-zedboard/td-p/905860
Yes. This is a quite helpful post. Thanks for sharing. :-)
Best Regards,
Jason
What is the use of this document? Guess by name, it should be using DNNDK tools on zedboard.
which document do you mean?
