B1D1ng
Can Darknet-yolov4 be deployed to the PYNQ board through DNNDK?
I saw a similar post before. It seems that the structure of the model needs to be modified. What modifications should be made to it to be deployed to the board through DNNDK? Looking forward to your reply, thank you
jasonwu
Hi @B1D1ng ,
Similar question on the other post. Currently the answer is the same.
As I know we don't provide yolov4 sollution yet.
There is a discussion on the other post:
https://forums.xilinx.com/t5/AI-and-Vitis-AI/Yolov4-support-to-DNNDK/m-p/1103325#M4001
Maybe you can find more information on that.
And for Pynq latest status I would suggest you to check the Pynq support forum:
https://discuss.pynq.io/
Best Regards,
Jason
jasonwu
Hi @B1D1ng ,
Best Regards,
Jason
B1D1ng
Thank you!
