longway2go
Can we customize quantizers different from vai_q_tensorflow?
Hi all!
Thanks for your hard work on Vitis-AI! Is it possible that we can implement our own quantizers and use them in the Vitis-AI work flow?
jasonwu
Hi @longway2go ,
As I know our VAI compiler can only be compliance with result from VAI quantizer.
You may have a try but I can not guarantee the result.
Best Regards,
Jason
