Cannot find Xilinx MLsuite documentation
I am currently trying to build my own application using Caffe for on premise application. However, I cannot find any documentation about classes and methods that available in Xilinx Caffe MLsuite. I can use the other example source code as referece ( https://github.com/Xilinx/ml-suite ) , but it is not enough. Is there any decent documentation for Xilinx MLsuite? if possible, I would be happy if there are documentations of Xilinx MLsuite for both caffe and tensorflow toolkit
Re: Cannot find Xilinx MLsuite documentation
Hi @fransiskusyoga ,
I am afraid that I just know the github ml-suite repository is for document release.
Here are 2 examples about how to deploy your models into Alveo board:
https://github.com/Xilinx/ml-suite/tree/master/examples
e.g. You can find download model/quantize/deploy model on FPGA flow from here:
https://github.com/Xilinx/ml-suite/tree/master/examples/tensorflow
Or the Vitis AI is released maybe you find some additional information from there:
https://github.com/Xilinx/Vitis-AI
Best Regards,
Jason
Best Regards,
Jason
