Hi, I'm trying to port ssd_mobilenet_v2_coco that I downloaded from the Tensorflow Model Zoo https://github.com/tensorflow/models/blob/master/research/object_detection/g3doc/detection_model_zoo.md
The quantization has worked, but I get an error when I try to compile the quantized model:
dnnc-dpu1.4.0 --parser=tensorflow \
--frozen_pb=quantize_results/deploy_model.pb \
--output_dir=dnnc_output \
--mode=normal \
--dpu=4096FA \
--cpu_arch=arm64 \
--net_name=ssd_mobilenet_v2_coco
This is the error:
[DNNC][Fatal] Check failed for condition [nodes_map_.find(pre_name) != nodes_map_.end()] in [/tmp/DNNC_V010_Package/dnnc/dnnc_impl/parser/tf/tfgraph.h:188] : Invalid tensorflow::GraphDef proto file: input node for current node [Preprocessor/map/while/add/y] doesn't exist.
*** Check failure stack trace: ***
How can I solve this problem?
