DNNC compilation error
I am trying action recognition using 3D convolution with tensorflow. When I run decent_q.sh, I get the following warnings:
INFO: Calibration Done.
INFO: Generating Deploy Model...
[DEPLOY WARNING] Node strided_slice(Type: StridedSlice) is not quantized and cannot be deployed to DPU,because it has unquantized input node: strided_slice/stack. Please deploy it on CPU.
[DEPLOY WARNING] Node transpose(Type: Transpose) is not quantized and cannot be deployed to DPU,because it has unquantized input node: pool5. Please deploy it on CPU.
[DEPLOY WARNING] Node Reshape(Type: Reshape) is not quantized and cannot be deployed to DPU,because it has unquantized input node: transpose. Please deploy it on CPU.
INFO: Deploy Model Generated.
Now, when I run dnnc_ZCU104.sh i get the following error:
DNNDK : 3.1
Board Name : ZCU104
DCF file : ../../../dcf/ZCU104.dcf
CPU Arch : arm64
DNNC Mode : debug
dnnc version v3.00
DPU Target : v1.4.0
Build Label: Aug 9 2019 13:19:12
Copyright @2019 Xilinx Inc. All Rights Reserved.
[DNNC][Error] 'Const' op should be fused with current op [StridedSlice] by DECENT.
Can someone please help me resolve this error!
Visitor pheles
Re: DNNC compilation error
Hi James,
without really knowing the example you are working through: you need to get rid of these [DEPLOY WARNING] messages. Those are operators that cannot be placed into DPU resources. This can be done by defining --output_nodes prior to the strided_slice operator when executing the decent tool. Any operator after that node must be coded inside your inference software.
Hope that helps!
André
