DNNC_error
Hi guys,
I quantized model mobilenet_ssd_v1_300x300 on VOC datasets. When I used decent_q that gave warning :
[DEPLOY WARNING] Node scale_logits(Type: RealDiv) is not quantized and cannot be deployed to DPU,because it has unquantized input node: scale_logits/y. Please deploy it on CPU.
[DEPLOY WARNING] Node convert_scores(Type: Sigmoid) is not quantized and cannot be deployed to DPU,because it has unquantized input node: scale_logits. Please deploy it on CPU.
[DEPLOY WARNING] Node raw_outputs/class_predictions(Type: Identity) is not quantized and cannot be deployed to DPU,because it has unquantized input node: convert_scores. Please deploy it on CPU.
INFO: Deploy Model Generated.
Therefore, dnnc_ZCU102.sh failed:
[DNNC][Error] 'Const' op should be fused with current op [RealDiv] by DECENT.
So what kind of this error, Could you help me to solve it ?
I am also facing the same kind of issue. Can you tell me how did you fix the error.
hi @jbond1007
In fact, I just skiped this node by --ignore_nodes flag and implement this node on CPU
I am facing same error. Can you please tell me how to implement unquantized nodes on CPU?
