DNNC support for maximum number of channels
        When I use dnnc to compile the model,Encountered some problems ,In order to solve my problem, I added the network layer by layer, but finally reported an error at a certain layer. The network of this layer is as follows, with 1152 output channels, and the kernel size is 5. I would like to ask whether DNNDK has Limitation of the maximum output channel.
layer {
type: "Convolution"
bottom: "Layer_55"
top: "Layer_56"
convolution_param {
num_output: 1152
bias_term: false
pad: 2
kernel_size: 5
group: 1152
stride: 1
dilation: 1
You may want to take a look at the features and parameters supported by DPU IP.
https://www.xilinx.com/support/documentation/ip_documentation/dpu/v3_1/pg338-dpu.pdf
pg21, Table 7
I have seen this before. The support is written on the PDF, but when I have 1152 output channels for two consecutive layers, dnnc will report an error, so I do n’t know if there is a limit on the combination of kernel_size and num_output.
Thank you for your help. When I add the 48th floor, an error occurs. Thank you very much.
layer {
type: "Convolution"
bottom: "Layer_46"
top: "Layer_47"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 1
decay_mult: 0
phase: TRAIN
convolution_param {
num_output: 1152
bias_term: true
pad: 0
kernel_size: 1
group: 1
stride: 1
dilation: 1
layer {
type: "ReLU"
bottom: "Layer_47"
top: "Layer_47"
phase: TRAIN
layer {
type: "Convolution"
bottom: "Layer_47"
top: "Layer_48"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 1
decay_mult: 0
phase: TRAIN
convolution_param {
num_output: 1152
bias_term: true
pad: 2
kernel_size: 5
group: 1152
stride: 1
dilation: 1
