DPU Configuration Parameter Description
Hi,The DPU1152,4*12*12, What does parameter 4 mean?
    I think 4 means that the parameter is quantized to 4bit, right?
Re: DPU Configuration Parameter Description
Please see PG338 (v2.0) p.22:
Thus, the 1st number refers to the pixel parallelism; the 2nd number refers to the input channel parallelism; and the 3rd number refers to the output channel parallelism.
@lvalena   thanks for your answer,I know this,but I am not sure the pixel parallelism mean,
I guess it is a clock that calculates four pixels  or  One pixel is represented by four bits,i am not sure.
Consider the VGG16 architecture.
The first layer, "Conv 1-1" has 3 input channels and 64 output channels. The second layer, "Conv 1-2" has 64 input channels and 128 output channels. The "pixels" are the elements in each blob (or tensor). Thus, "Conv 1-1" has 224x224x3 input pixels to process and generates 224x224x64 output "pixels" (or blob/tensor elements).
The DPU "pixel parallelism" refers to the number of *output* blob/tensor elements it can calculate per clock cycle.
