bestcarp
DPU (DPUCZDX8G) work go wrong with self hls kernel
platfrom:ZCU104
I tried to find the cause of the error using the controlled variable method ,but failed!
the DPU means DPUCZDX8G on ZCU104
 2 DPU1DPU1DPU with self hls kernel1DPU with another self hls kernel
Self net (n2cube api)
RightRightWrongWrong
Official VART sample
Self hls kernel--RightRight
picture shows the platform with (1 DPU) and (1 DPU with self hls kernel )
the error result follows
the cust net work right on offical img /(1 DPU )/(2 DPU)  ,but work error like this if I include myself hls kernel. i did't change the host code, what's more ,i also tried build dcf file with hwh res,then compile the (elf) file and the (so) file.
the offical VART example such as Video analysis work wrong at the same time.
【however, all my hls kernels test  work properly  with individual opencl host file.】
all my modify the scripts is followed like this
pp_1118_top_FLAGS := --kernel pp_1118_top -I. -I/home/wly/vitis_lib_2020_1/Vitis_Libraries/vision/L1/include -D__SDSVHLS__ -D__XF_USE_NEW_IMPL__
else ifeq ($(KERNEL),DPU)
kernel_xo = binary_container_1/dpu.xo binary_container_1/pp_1118_top.xo
binary_container_1/pp_1118_top.xo: my_pp_1118_accel.cpp
v++ -t ${TARGET} --platform ${SDX_PLATFORM} ${pp_1118_top_FLAGS} --temp_dir binary_container_1 --kernel_frequency=300 --log_dir binary_container_1/logs --config pp_1118_top_config.ini -c -o $@ $<
I don't know how this scripts can influence the dpu‘s’ work
【addition】
i tried build platform use offical sfm_xrt_top_1 base on  previous prj
it can‘’t work with n2cube api and work wrong with VART env same as before
bestcarp
bestcarp
I build this platform on ZCU102
modifyed form 【prj_config_102_3dpu_LPD】
it work all properly
what's the differenc between this two platform?
My operations are all standard,why zcu104 work error only if I connect  custom hls kernel??
graces
The Makefile looks good to me.
You mean with ZCU102 prj config file, DPU+custom HLS kernel work fine in hardware?
For the v++ package flow, by default, it creates an output file named a.xclbin. You can add "-o dpu.xclbin" to specify the output file name. Is this output dpu.xclbin copied to the target system?
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs.
qwqw0001
hi @bestcarp ,
    I am also doing this work recently, combining my own HLS core with DPU.  I would like to ask how to combine my HLS core with DPU. Should this combination be before petalinux builds the system?
     Do you have any relevant tutorials to share, thank you!
bestcarp
I refer to the github /Xilinx/Vitis-In-Depth-Tutorial
Vitis-In-Depth-Tutorial /Machine_Learning /Introduction /03-Basic /Module_7/
I hope it helped you
qwqw0001
hi @bestcarp ,
   OK, I will try it, thanks.
    ylh
bestcarp
these days,I try make 104 and 102 platforms on another computer,because I wonder if there is something wrong with my  environment.
The result is the same as before
with ZCU102 prj config file, DPU+custom HLS kernel work fine in hardware.(2 DPU 3 HLSkernel)
with ZCU104 prj config file, DPU+custom HLS kernel work error in hardware.(1 DPU 3 HLSkernel)
Another difference between the two config files is [strategy=Performance_ExploreWithRemap 0r Performance_NetDelay_low], which I don't think is causing the result.
I also don't think the ZCU104 FPGA is the problem, because it runs correctly without  HLS kernels.
bestcarp
Then I wonder if it is the amount of DPU that is causing the problem. The ZCU104 can only use one DPU with a B4096 architecture due to resource issues.
The result is that adding HLS kernel when there is only one DPU will cause the DPU to run incorrectly
RUN A same dpu APP (only use n2cube api ,not use hls kernel)
 1DPU No hls kernel2DPU No hls kernel1DPU with hls kernel2DPU with hls kernel
on ZCU104
Right
RightErrorNO resource
on ZCU102Not testNot testErrorRight
ALL test build a new sdcard_img,and the dpu.xclbin updata automatically and correctly.
I think it should be difficult for me to find the reason for this phenomenon, and I doubt whether there is a bug in DPU TRD
