DPU-TRD Vivado 2020.1 Flow - Petalinux build failing
I am trying to build Petalinux for the new DPU TRD version for Vivado 2020.1 just released and I am facing an error when building Petalinux. This is the build-flow that I am following:
https://github.com/Xilinx/Vitis-AI/tree/master/DPU-TRD/prj/Vivado
This is the output log when I hit:
petalinux-build
Output log:
INFO: sourcing build tools
[INFO] building project
[INFO] sourcing build environment
[INFO] generating user layers
[INFO] generating workspace directory
INFO: bitbake petalinux-image-minimal
Parsing recipes: 100% |###############################################################| Time: 0:13:08
Parsing of 2963 .bb files complete (0 cached, 2963 parsed). 4232 targets, 167 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
NOTE: Fetching uninative binary shim from file:///home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/downloads/uninative/9498d8bba047499999a7310ac2576d0796461184965351a56f6d32c888a1f216/x86_64-nativesdk-libc.tar.xz;sha256sum=9498d8bba047499999a7310ac2576d0796461184965351a56f6d32c888a1f216
Initialising tasks: 100% |############################################################| Time: 0:00:26
Checking sstate mirror object availability: 100% |####################################| Time: 0:00:10
Sstate summary: Wanted 2570 Found 0 Missed 2570 Current 0 (0% match, 0% complete)
NOTE: Executing Tasks
NOTE: Setscene tasks completed
WARNING: dnndkdeploy-1.0-r0 do_fetch: Failed to fetch URL file:///proj/yocto/dnndk/zynqmp_latest, attempting MIRRORS if available
ERROR: dnndkdeploy-1.0-r0 do_fetch: Fetcher failure: Unable to find file file:///proj/yocto/dnndk/zynqmp_latest anywhere. The paths that were searched were:
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/petalinux
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/petalinux
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/petalinux
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/zcu102-zynqmp
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/zcu102-zynqmp
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/zcu102-zynqmp
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/armv8a
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/armv8a
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/armv8a
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/aarch64
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/aarch64
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/aarch64
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/cortexa72-cortexa53
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/cortexa72-cortexa53
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/cortexa72-cortexa53
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/zynqmp
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/zynqmp
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/zynqmp
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/zynqmpeg
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/zynqmpeg
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/zynqmpeg
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/mali400
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/mali400
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/mali400
    /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/build/downloads
ERROR: dnndkdeploy-1.0-r0 do_fetch: Fetcher failure for URL: 'file:///proj/yocto/dnndk/zynqmp_latest'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/build/tmp/work/zynqmp-xilinx-linux/dnndkdeploy/1.0-r0/temp/log.do_fetch.30195
ERROR: Task (/home/jalezeta/Documents/Vitis-AI/DPU-TRD/prj/Vivado/dpu_petalinux_bsp/xilinx-zcu102-trd/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6996 tasks of which 0 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
Thanks all
wastie
I Have the same problem with 2020.1
Checking sstate mirror object availability: 100% |###############################################################################################################################################| Time: 0:00:21
Sstate summary: Wanted 458 Found 18 Missed 440 Current 2086 (3% match, 82% complete)
NOTE: zocl: compiling from external source tree /local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/workspace/sources/zocl/src/runtime_src/core/edge/drm/zocl
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/petalinux
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/petalinux
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/petalinux
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/zcu102-zynqmp
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/zcu102-zynqmp
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/zcu102-zynqmp
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/armv8a
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/armv8a
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/armv8a
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/aarch64
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/aarch64
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/aarch64
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/cortexa72-cortexa53
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/cortexa72-cortexa53
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/cortexa72-cortexa53
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/zynqmp
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/zynqmp
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/zynqmp
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/zynqmpeg
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/zynqmpeg
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/zynqmpeg
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy-1.0/mali400
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy/mali400
/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/files/mali400
/local/home/wastiel/platform/zcu102_base/petalinux/build/downloads
ERROR: Logfile of failure stored in: /local/home/wastiel/tmp/xilinx-zcu102-2020.1-2020.05.30-16.13.44-W9g/work/zynqmp-xilinx-linux/dnndkdeploy/1.0-r0/temp/log.do_fetch.14079
ERROR: Task (/local/home/wastiel/platform/zcu102_base/petalinux/components/yocto/layers/meta-vitis-ai/recipes-support/dnndk/dnndkdeploy.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6592 tasks of which 6266 didn't need to be rerun and 1 failed.
Makefile:25: recipe for target 'linux' failed
make[1]: *** [linux] Error 255
make[1]: Leaving directory '/local/home/wastiel/platform/zcu102_base/petalinux'
Makefile:21: recipe for target 'petalinux_proj' failed
make: *** [petalinux_proj] Error 2
w
Dear @wastie,
I have posted an Issue on the GitHub repository of Vitis-AI related to this specific build error. They have kindly responded to me on how to fix the error. We need to modify the config file by adding Network sstate feeds URL. I am sending you the link to the Issue on GitHub so you can solve the problem as well. Anyway, they have updated the BSP to solve the build error, so we can either solve the problem or download the latest project and re-build Petalinux.
https://github.com/Xilinx/Vitis-AI/issues/118
PD: I have tried to modify the config file as explained on the GitHub and now I can build Petalinux perfectly.
wastie
this didn't fix my issue
katsuki
Hi @wastie @jalezeta_ikerlan
Git data has been updated. If you clone it, the build will be successful.
No need for petalinux-config for xrt and zocl.
Thank you
Please mark the Answer as Accept as Solution if information provided is helpful.
Don’t forget to reply, kudo, and accept as solution. If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
