DPU TRD for Zedboard
I am having makefile for ZCU102.
how can i modify the make file of ZCU102, to generate RESNET 50 FOR ZEDBOARD
回复: DPU TRD for Zedboard
Did you rebuild the SDK?
Pls. try the following steps.
cd $TRD_HOME/apu/dpu_petalinux_bsp/your_petlinux_project
petalinux-build --sdk
cd $TRD_HOME/apu/dpu_petalinux_bsp/your_petlinux_project/images/linux
./sdk.sh -d ./sdk -y
unset LD_LIBRARY_PATH
. $TRD_HOME/apu/dpu_petalinux_bsp/your_petlinux_project/images/linux/sdk/environment-setup-cortexa9t2hf-neon-xilinx-linux-gnueabi
## Build the resnet50 example
cd $TRD_HOME/apu/apps/resnet50
make
Re: DPU TRD for Zedboard
See my Makefile.
You need to change the path to match your computer.
PROJECT = resnet50
SYSROOT = /home/bkkim/workpsace/EFIS/petalinux/images/linux/sdk/sysroots/x86_64-petalinux-linux
CXX := arm-linux-gnueabihf-g++
CC := arm-linux-gnueabihf-gcc
OBJ := main.o
# linking libraries of OpenCV
LDFLAGS += $(shell PKG_CONFIG_PATH=${SYSROOT}/usr/lib/pkgconfig pkg-config --libs opencv)
# linking libraries of DNNDK
LDFLAGS += -lhineon -ln2cube -ldputils -lpthread
CUR_DIR = $(shell pwd)
src=$(CUR_DIR)/src
BUILD = $(CUR_DIR)/build
MODEL = $(CUR_DIR)/model
VPATH = $(SRC)
CFLAGS := -O2 -Wall -Wpointer-arith -std=c++11 -ffast-math -mcpu=cortex-a9 -mfloat-abi=hard -mfpu=neon
CFLAGS += --sysroot=${SYSROOT}
MODEL = $(CUR_DIR)/model/dpu_resnet50_0.elf
.PHONY: all clean
all: $(BUILD) $(PROJECT)
$(PROJECT) : $(OBJ)
$(CXX) $(CFLAGS) $(addprefix $(BUILD)/, $^) $(MODEL) -o $@ $(LDFLAGS)
%.o : %.cc
$(CXX) -c $(CFLAGS) $< -o $(BUILD)/$@
clean:
$(RM) -rf $(BUILD)/*.o $(BUILD)
$(RM) $(PROJECT)
$(BUILD) :
-mkdir -p $@
Best regards,
And if you create the petalinux image following the steps in https://github.com/Xilinx/Edge-AI-Platform-Tutorials/tree/master/docs/DPU-Integration
You can also try the SDK building flow inside: Chapter "Build Machine Learning Applications Using Xilinx SDK"
Best Regards,
Jason
Thanks for ur reply.
but i am getting the following error:
sahoo@sahoo-Veriton-M4630G:~/ZED_chek_oct18/image_creation_resnet50/resnet50$ make
aarch64-linux-gnu-g++ -c -O2 -Wall -Wpointer-arith -std=c++11 -ffast-math -mcpu=cortex-a9 -mfloat-abi=hard -mfpu=neon --sysroot=/home/sahoo/ZED_chek_oct18/image_creation_resnet50/sdk/sysroots/aarch64-xilinx-linux /home/sahoo/ZED_chek_oct18/image_creation_resnet50/resnet50/src/main.cc -o /home/sahoo/ZED_chek_oct18/image_creation_resnet50/resnet50/build/main.o
aarch64-linux-gnu-g++: error: unrecognized command line option ‘-mfloat-abi=hard’
aarch64-linux-gnu-g++: error: unrecognized command line option ‘-mfpu=neon’
Makefile:80: recipe for target 'main.o' failed
make: *** [main.o] Error 1
i am attaching my original makefile also
What is your test environment?
If you are using Zedboard,
Cross compilers should use 'arm-linux-gnueabihf-'.
aarch64-linux-gnu- is a compiler for MPSoc.
I AM USING ZEDBOARD
MY ORIGINAL MAKE FILE IS LIKE THIS:
PROJECT = resnet50
SYSROOT = /home/sahoo/ZED_chek_oct18/image_creation_resnet50/sdk/sysroots/aarch64-xilinx-linux
CXX := aarch64-linux-gnu-g++
CC := aarch64-linux-gnu-gcc
OBJ := main.o
src=$(CUR_DIR)/src
VPATH = $(SRC)
CFLAGS := -O2 -Wall -Wpointer-arith -std=c++11 -ffast-math -mcpu=cortex-a53
.PHONY: all clean
$(PROJECT) : $(OBJ)
$(CXX) $(CFLAGS) $(addprefix $(BUILD)/, $^) $(MODEL) -o $(BUILD)/$@ $(LDFLAGS)
%.o : %.cc
clean:
$(RM) -rf $(BUILD)
$(BUILD) :
-mkdir -p $@
AFTER CREATING  IMAGE FOE RESNET 50, WHEN I TYPE ./RESNET50 IN ZEDBOARD LINUX TERMINAL
IT REPLY: EXECUTION FORMAT ERROR
The path of SYSROOT is not valid.
The compiler was incorrectly specified.
The Make file you use is for ZynqMP.
Edit the entry below by referring to the file I showed.
=> SYSROOT, CFLAGS, CXX, CC
can u please tell me how to get this "Cross compilers should use 'arm-linux-gnueabihf-'"
after runnin sh sdk.sh (this sdk.sh i have collected from ZCU102), inside sysroot the folders are : "aarch64-xilinx-linux" and "x86_64-petalinux-linux".
from where i can get the ross compilers should use 'arm-linux-gnueabihf-, or sdk.sh file is different for zedboard.
can u please tell me from where i can get sdk.sh for zedboard to create image file for resnet 50.
Best Regards and Thanks
as u told , i download cross compiler Cross compilers should use 'arm-linux-gnueabih-'., but now the error is
Makefile:75: recipe for target 'resnet50' failed
can u please suggest, my new makefile is like this (ZEDBOARD)
PROJECT = resnet50
SYSROOT = /home/sahoo/ZED_chek_oct18/image_creation_resnet50/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi
CXX := arm-xilinx-linux-gnueabi-g++
CC := arm-xilinx-linux-gnueabi-gcc
OBJ := main.o
src=$(CUR_DIR)/src
VPATH = $(SRC)
.PHONY: all clean
$(PROJECT) : $(OBJ)
%.o : %.cc
clean:
$(RM) -rf $(BUILD)
$(BUILD) :
-mkdir -p $@
after following ur steps for my zedboard i am getting following error:
fatal error: dnndk/dnndk.h: No such file or directory
make
root@zed_deephi:/media/card/build# ./resnet50
Warning:
The DPU in this TRD can only work 8 hours each time!
Please consult Sales for more details about this!
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e1e51 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e1ef1 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e1f91 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2031 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e20d1 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2175 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2215 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e22b5 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2359 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e23f9 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2499 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e253d FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e25dd FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e267d FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e271d FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e27c1 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2861 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2901 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e29a5 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2a45 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2ae5 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2b89 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2c29 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2cc9 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2d6d FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2e0d FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2ead FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2f4d FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e2ff1 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3091 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3131 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e31d5 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3275 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3315 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e33b9 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3459 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e34f9 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e359d FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e363d FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e36dd FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3781 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3821 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e38c1 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3965 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3a05 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3aa5 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3b45 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3be9 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3c89 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3d29 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3dcd FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3e6d FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3f0d FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e3fb1 FSR 0x011
Alignment trap: resnet50 (1464) PC=0xb6c67b36 Instr=0xe9d60102 Address=0xb48e4001 FSR 0x011
total image : 10
[DPU][1468][PID 1468][taskID 4]Core 0 Run timeout,failed to get finish interrupt!
[DPU][1468][DPU debug info]
level = 9
[DPU][1468]Core 0 schedule counter: 1
[DPU][1468]Core 0 interrupt counter: 0
[DPU][1468][DPU Registers]
[DPU][1468]VER : 0x09298cfb
[DPU][1468]RST : 0x000000ff
[DPU][1468]ISR : 0x00000000
[DPU][1468]IMR : 0x00000000
[DPU][1468]IRSR : 0x00000000
[DPU][1468]ICR : 0x00000000
[DPU][1468]
[DPU][1468]DPU Core : 0
[DPU][1468]HP_CTL : 0x07070f0f
[DPU][1468]ADDR_IO : 0x00000000
[DPU][1468]ADDR_WEIGHT : 0x00000000
[DPU][1468]ADDR_CODE : 0x00018048
[DPU][1468]ADDR_PROF : 0x00000000
[DPU][1468]PROF_VALUE : 0x00000000
[DPU][1468]PROF_NUM : 0x00000000
[DPU][1468]PROF_EN : 0x00000000
[DPU][1468]START : 0x00000001
[DPU][1468]COM_ADDR_L0 : 0x18300000
[DPU][1468]COM_ADDR_H0 : 0x00000000
[DPU][1468]COM_ADDR_L1 : 0x1a500000
[DPU][1468]COM_ADDR_H1 : 0x00000000
[DPU][1468]COM_ADDR_L2 : 0x18048000
[DPU][1468]COM_ADDR_H2 : 0x00000000
[DPU][1468]COM_ADDR_L3 : 0x00000000
[DPU][1468]COM_ADDR_H3 : 0x00000000
[DPU][1468]COM_ADDR_L4 : 0x00000000
[DPU][1468]COM_ADDR_H4 : 0x00000000
[DPU][1468]COM_ADDR_L5 : 0x00000000
[DPU][1468]COM_ADDR_H5 : 0x00000000
[DPU][1468]COM_ADDR_L6 : 0x00000000
[DPU][1468]COM_ADDR_H6 : 0x00000000
[DPU][1468]COM_ADDR_L7 : 0x00000000
[DPU][1468]COM_ADDR_H7 : 0x00000000
[DPU][1468]
[DNNDK] DPU timeout while execute DPU Task [resnet50_0-4] of Node [conv1]
can u please address this
Do you see the DPU interrupt? You can have a look by using this command: cat /proc/interrupts
After running this command
root@zed_deephi:/media/card/face_detection/model# cat /proc/interrupts
CPU0 CPU1
16: 1 0 GIC-0 27 Edge gt
17: 0 0 GIC-0 43 Level ttc_clockevent
18: 2316 4559 GIC-0 29 Edge twd
19: 0 0 GIC-0 37 Level arm-pmu
20: 0 0 GIC-0 38 Level arm-pmu
21: 43 0 GIC-0 39 Level f8007100.adc
24: 0 0 GIC-0 35 Level f800c000.ocmc
25: 266 0 GIC-0 82 Level xuartps
26: 8 0 GIC-0 51 Level e000d000.spi
27: 0 0 GIC-0 54 Level eth0
28: 3753 0 GIC-0 56 Level mmc0
29: 0 0 GIC-0 45 Level f8003000.dmac
30: 0 0 GIC-0 46 Level f8003000.dmac
31: 0 0 GIC-0 47 Level f8003000.dmac
32: 0 0 GIC-0 48 Level f8003000.dmac
33: 0 0 GIC-0 49 Level f8003000.dmac
34: 0 0 GIC-0 72 Level f8003000.dmac
35: 0 0 GIC-0 73 Level f8003000.dmac
36: 0 0 GIC-0 74 Level f8003000.dmac
37: 0 0 GIC-0 75 Level f8003000.dmac
38: 0 0 GIC-0 40 Level f8007000.devcfg
44: 0 0 GIC-0 53 Level e0002000.usb
45: 0 0 GIC-0 41 Edge f8005000.watchdog
46: 94 0 GIC-0 90 Level 41600000.i2c
47: 0 0 GIC-0 91 Edge 43c20000.dma
48: 0 0 GIC-0 61 Edge dpu_isr
IPI1: 0 0 Timer broadcast interrupts
IPI2: 1659 2272 Rescheduling interrupts
IPI3: 2 2 Function call interrupts
IPI4: 0 0 CPU stop interrupts
IPI5: 0 0 IRQ work interrupts
IPI6: 0 0 completion interrupts
